Brief Description: Built and mounted fuselage on a rotisserie
Decided to build a rotisserie for the fuselage to make it easier to work on. Based the front part on images from the Web. Made up the rear part using a wood block to distribute the load at the tail. Used 2 engine stands. The system works really well and should make it easier for wiring, painting, etc.
