Clecoed the side skins to the fuselage frame assembly. Cut and fit the hinge sections and shims to the front side of the firewall which will be used to attach the cowling. Match drilled all the mounting holes, then countersunk and dimpled the hinge and shims. Finished by deburring and priming.
