Brief Description: Riveting bottom skin to left flap
Attached two straight rulers to flap hinges to act as winding sticks to assure there will be no twist in the flap. Sighting between the two rulers and shimming the wooden supports with old credit cards until the rulers were perfectly aligned did the trick. Started to rivet the skins along the spar.
Aligning hinge brackets to assure no twist in flap structure
