Brief Description: Continued fabrication of elevator stiffeners
Continued fabrication of elevator stiffeners. Used my bandsaw to cut the trailing edge portion, then used a file to clean up the cut, and finally used a scotchbrite wheel to debur the edges. I messed up on the left stiffener 720J that is made from a 720D stiffener. I cut too much of the trailing edge off. I misread the plans and cut it an inch short.
