BRANDEN'S WEB SITE
Date:  7-25-2010
Brief Description:  Prepaired and Primed Left HS skeleton
I had previously primed the right HS parts with the rudder parts to keep the left and right seperated. I marked the right primed parts and started to work on the left side parts.
I cleaned the left HS skeleton parts and used EkoEtch, then washed and dried the spars/ribs.
I used my Harbor Freight HVLP gun and shot the Stewart Systems primer. No smell and a quick clean up with water. I ended up just adding the distilled water to the paint can until the viscosity was around 20-25 seconds.
