BRANDEN'S WEB SITE
Date:  3-18-2011
Brief Description:  Fitting the right counterballance weight
I followed the instructions and prepaired the counterballance rib and tip rib by fluting. FItted the rib assembly to the counterballance skin and spar. I match drilled the assembly where the instructions indicated to with a #30 drill bit. I also marked the counterballance weight to cut the excess off of the tip per the plans.
