Brief Description: Match Drilled Right HS skeleton #30
Started on the Right HS parts. I had cut both the right and left HS-404 nose rib previously and now I see that I cut the Right HS-404 too much to clear the reinforcement bars and caused an edge distance problem on the first skin rivet hole near the front spar on the HS-404. I ordered a new one from Vans.
I again drilled the HS-708 to HS-603PP hole to #23 instead of #21 to get a tighter fit for the pop rivet called out there.
Completed the mudane stuff related to the Right HS such as debur the edges of the ribs/spars and deburred the #30 holes.
Set the Right HS aside waiting for the replacement HS-404.
