I located and marked and then drilled holes on each side of the gap fillers that will hold it to the spinner (nutplates will be installed in the gap fillers. Then reinstalled the forward hub and spacers and reattached the spinner because I have to open up all the #30 holes to #19. I decided to wait and order new #19 drill bits and also some #19 clecos as I have none and if you follow the directions without having #19 clecos, you'll be in big trouble.
Unfortunately, because of COVID-19 restrictions, Cleveland is only shipping on Fridays and Tuesdays so I don't know whether 2:30 on a Friday gets out the door in time for the weekend.
I can wait because the anti-seize order came and I can work on attaching the muffler.
