SD-00001 requires replacement of the Rob Allen mot.or that powered the trim with a new motor. That's another $200 fix for parts that haven't even flown yet.
I disassembled the existing control arm and motor, made up a new servo tray, and attached a bushing and clevis which is finger tightened to 15 degrees and then, with a drop or two of Threadlocker, final tightened to 0 degrees (perpendicular to the tray.
Just to be sure no Threadlocker dripped down into the motor and shaft, I stood the unit on its Clevis overnight until cured.
