Started on the gear leg fairing after doing some more adjustments on the nosewheel fairing to make it fit just a little bit better.
Then removed the wheel fairing and sanded the gear leg fairing down to the scribe line, cut out the slot for the winch attachment, fit it to the gear leg, added plum bobs on either side to get it centered, and then drilled three holes in the "extra material" along its length as directed.
