Brief Description: Identified left wheelpant problem
I couldn't get the wheelpant to fit quite right because of the brake line interference and some requests on the Facebook VAF page revealed the cause. For some reason, and only on the left side, I ran the loop on the bottom of the brake line OVER the landing gear leg instead of under it as it comes off the line, thus causing interference.
I don't have enough ATO-032x1/4 tubing so I've ordered more and removed the offending brake line.While doing that, I notice the AN angle fitting on the caliper wasn't very tight so I gave that another turn.
