Bought some Aeroshell 5 grease and soaped up the bushings on the nose gear fork. Put some Threadlocker 243 on the two allen screws that act as stops for the fork and attached it to the nose gear fork.
Used a spring scale to set the tension on the castle nut to require an 18-20 pound pull.
I still have to drill through the fork for the cotter pin.
