Brief Description: Main wheel and tire installation
In fits and starts I figured out the main wheel and how to take it apart. And was able to easily get the tire stem through the side hole and down through the main wheel. Then reinstalled the hub and installed the tube and wheel into the tire.
The air filler I'm using doesn't seem to like this valve so I'm going to bring the bicycle pump over to the hangar.
In the meantime, I've ordered Aeroshell 22 grease to grease up the wheel bearings.
