Brief Description: Attached flap assembly control tubes
I was a little confused because when I added the rod end bearings to the control tube ends (with jam nuts, of course), they came up too long. I even sent a note to Van's. As it turned out, the marks I'd made on the worktable to measure the center hole to center hole distance was an inch too short.
Duh.
Anyway, on Thanksgiving morning, I attached the control tubes to the mixture brackets in the cabin and then installed the brackets on the rod end bearings on the rib near the most rear bulkhead and then attached the tubes to those brackets.
