Match-drill/deburr parts to replacement Ail. spar Prime L. Ail. assembled skeleton Clean white primer off Wing rear spars Prime R. Ail. ribs/reinf. plates Prime both ail. nose skins alodine/prime replacement ail. spar Adjusted flap nose rib flanges to 90 degrees Clecoed nose ribs/spacers/hinge brackets together
