Brice Bowman RV-9A
RV-9A
HS, Wing
1) Started fluing Wing Main Ribs 2) Rivet HS Rear Spar to skin around hinges 3) Riveted outboard HS Ribs to skin 4) Finished riveting outboard HS Ribs to skin 5) Bolted on/Torqued HS Hinge Bracket to Rear Spar (Stripped Bolts - oredered replacements) 6) Fit Fiberglass Tips To HS - drilled/clecoed
RV-9A Home
1301
205
312
Tools/Shop Supplies
776
