Brice Bowman RV-9A
RV-9A
Fwd Fuselage Parts
Extend flap actuator to 1/2 travel w/+12volts
Bolt actuator motor into flap channel/install
Fit/Drill Angle in flap channel
Deburr/rivet angle to flap channel
Dril 1/2" holes in F-982-E panel for mixture, throttle, carb heat cables
Drill safety wire hole in flap motor arm
Drill flap actuator - center nylon bushing to floor w/#10 drill
Trim baggage floor tunnel cover - notch at nylon flap bushing
Match-drill baggage floor for platenuts & rivets (#40)
Pop-rivet aft seat floor
Remove pop-rivets in baggage floor & remove floor panels to install steps
RV-9A Home
1301
205
312
Tools/Shop Supplies
776
