DRILLED HOLES THROUGH TH LOWER LONGERONS FOR MOUNTING BOLTS FOR AILERON BELLCRANKS. TEMPORARILY MOUNTED IN POSITION AND ADJUSTED THE LENGTH OF THE CONTROL RODS. STILL HAVE TO WELD THE BOLTS INTO THE LOWER LONGERONS, AND ORDER THE PROPER BOLTS FOR CONNECTION.
