The top of the baffle seals have several seams and partial seams as it runs between baffle sections. I wanted a way to hold these together and to put a natural inward curve to the seals so they sit against the upper cowl. I used nylon tie line (used to secure wiring bundles) and put stitchs into the top of each seam. This holds the seal together and can easily be cut to allow baffle sections to be removed.
