I finished the final fit of the baffles, then removed them from the engine. I then carefully cleaned and vacuumed up all aluminum bits from the cooling fins on the engine. I also final drilled the baffle attachment holes where they are bolted to the engine, as this helps avoid cracking of the baffles.
