Brief Description: Installed mounting bracket to wheel pants
The inner part of the aft section of the wheel pants are attached with screws which require nutplates installed onto the wheel bracket. I positioned and drilled these, cleaned up and countersunk these then riveted in place. The outer side has a bracket riveted to the wheel pant and a bolt holds this to the axel nut. I drilled, countersunk and riveted these brackets in place. I also installed the nutplates onto the wheel pants.
