Bobs RV7 Site
Date:  2-5-2013
Number of Hours:  1.00
Brief Description:  Adjusted Mixture
I began by downloading engine data from yesterdays engine run. You can graph this data which would be usefull in analyzing any engine problem. Nothing seemed abnormal from the engine run.
The engine run indicated that the mixture is set a little too lean, so I adjusted the mixture 3 clicks richer and will check this on the next engine run.
