Ininstalled the pressure lines that run from the wing sensors to the Angle of Attack CPU behind the instrument panel. The lines attach to the sensors then run the length of the wing through the wiring conduit and will terminate at the wing root with a disconnect fitting. From the wing root the line runs into the fuselage alongside the pitot tube line up to the instrument panel and attaches to the CPU.
