I began installing the antenna wire into the wings. The VHF nav antenna will be mounted in the right wing tip and will provide VOR/LOC/GS inputs for the Garmin system. The marker beacon antenna will be mounted in the left wingtip. Both antennas cable is routed through the extra conduit that I had installed earlier in each wing so that the strobe wires could be separated. I installed BNC connectors and installed cushioned clamps. I also began routing the wiring for the fuselage antennas. The GPS mounting holes and BNC connector is shown. I may wait until final assembly before mounting the antennas.
