Bobs RV7 Site
RV-7
Instrument panel
2-11-2009
Vacuum System
I made a mount for the vacuum intake filter and installed it using nut plates to make it more accessable for filter replacement. I then drilled the firewall for the vacuum regulator and mounted the regulator with high temp RTV to seal the hole.
RV-7 Home
2286
Administrative
Baffeling
Cowling
238
140
Empennage / Elevator
Empennage / HS
Empennage / Rudder
Empennage / VS
241
Instrument panel
163
Landing gear & brake
Systems
Upholstery
183
