I planned the static line run from the static port to the instrument panel. Decided that the best run would be below the upper side cockpit deck. Drilled and inserted plastic bushings into access holes. I protected the static line with flexible plastic hose where it passed along any possible chafing areas. Ran and secured the static line.
