Brief Description: Wiring run from engine to firewall
I continued the wire runs toward the center of the upper engine mount, securing each with cushioned clamps. I also continued the ignition wire runs through the rear baffels to their ignition units mounted on top of the engine. I'm still considering whether to make one large hole in the firewall for the wiring run, or to make two smaller holes and split the wiring between them. Two holes could make the wire bundle easier to handle on the instrument panel side of the firewall. I'll decide that next week.
