Brief Description: Riveted cowling to fuselage hinge
I riveted the cowl hinge to the fuselage along the bottom and sides. Most of the bottom hinge and the lowest few rivets on each side were done with blind rivets as there was insufficient room along the engine mount for a bucking bar or rivet yoke. The upper cowl hinge will be riveted later when the last top skin of the fuselage (above the instrument panel) is riveted in place.
