I installed the cylinder head sensors, then began installing the exhaust gas temperature probes into the exhaust pipes. I had to be careful to insure that the EGT probes would not interfere with the spark plugs. I drilled and installed the EGT probes. I also ran the ingition wires from the magneto to the lower spark plug holes, then secured them with cushioned clamps using valve cover bolts.
I'll still have to secure and neated up the wiring runs of the CHT and EGT wires.
