Bobs RV7 Site
Date:  1-19-2006
Number of Hours:  4.00
Brief Description:  Re did brake system connections
When I installed the brake system I used teflon tape on the connections. Several builders have had problems with "weeping" or leaking of these connectors using tape and most recommend using a teflon paste to better seal the connectors. I decided to replace the tape. With the panel and wiring installed it was a very slow and time consuming process, but it went well and hopefully will be worth the extra effort.
