Bobs RV7 Site
RV-7
Systems
5-7-2004
Aileron trim
Manufactured the mounting plate for the aileron trim assembly. Drilled the plastic mounting block. Drilled, dimpled and primed the aluminum parts. Attached nutplates and attached the servo rod to the trim arm.
RV-7 Home
2286
Administrative
Baffeling
Cowling
238
140
Empennage / Elevator
Empennage / HS
Empennage / Rudder
Empennage / VS
241
Instrument panel
163
Landing gear & brake
Systems
Upholstery
183
