I had installed the pilots seat when I was setting the position of the rudder pedals. I am holding off on installing the entire interior until after I do the first engine run. I want to be able to check for any fuel system leaks and also want to have other builders look over the construction of the airplane so want access to all areas of the cockpit.
I did install the side panels as these don't cover any of the areas I want to monitor. It shows a glimpse of what the final interior will look like.
