I began installing foam in the interior. I had previously made templates of the interior panels for this purpose and they made the job much easier now that the instrument panels has been installed. The primary reason for this insulation is to cut the noise and heat from penetrating the firewall. I also decided to add some along the side of the cockpit as insulation from cold.
