I began preparing to mate the wings. Rearranged the shop to accomodate the fuselage and wings when assembled. Built a support for the fuselage and leveled this per the instructions. Built support dollies for the wings. I had to drill out several rivets on the inboard edges of the wing skins which will be used to attach the wing fairing. These were mistakenly riveted in the quick-build wings. I pre-positioned the control rods inside the wings. I made several drift pins to aid in aligning the spar with the bolt holes.
