Brief Description: Lightspeed ignition power wiring
The Lightspeed ignition needs a 12 volt power supply from the battery. This input is through a 5 amp circuit breaker on the instrument panel. I routed this wire and the negative lead from the battery negative post to the ignition box. I also assembled and wired the input connector to the Lightspeed control box. This connector attaches wiring from the ignition/start key.
