I decided to add two more map lights, these being mounted on the roll bar to provide light from above. These will supplement the two map lights installed on the cockpit side covers. I manfactured mounts for the lights that will use the existing bolts for the roll bar handles. I also manfactured a support bar for the instrument panel structure. This support will hold the electrical feeder lined from the alternator and battery on their run to the circuit breaker panel.
I drilled, deburred, primed and painted the mounts and support.
