While I had the cirbuit breaker panel apart I decided to reconfigure the bus bars. The initial CB panel was assembled by Pacific Coast Avionics and some of the busses were divided up for no apparent reason. I do have the avionics on separate busses which are powered through an avionics relay. The other items can all be on the same physical bus since they are all powered when the master switch is on. I trimmed and drilled copper strips for the new busses and attached the rows of CB's to them. This reduced the number of connecting wires behind the panel and reduced the clutter and complexity.
