Adjusted the fit of the inboard lower flap skin against the fuselage bottom. Removed the flap position switch system, as it failed and must be returned for repairs. In preparation for removing the wings, I had to remove the flaps. Decided to modify the flap hinge pin into a two piece pin. This makes flap removal much easier when the ailerons are attached. Also fixed the ailerons in the faired position so that the tips can be fitted after the wings are removed.
