Cut a hole in the leading edge, trimmed and finished the cut. Drilled plate nuts to the wing ribs for the light adjustment screws. Drilled holes in the light mounting plate for plate nuts and assembly. Deburred all holes, dressed edges, dimpled or countersunk holes as necessary. Primed all parts using NAPA 7220 self etching primer.
