Primed the HS frame structure. Pre-cleaned all parts with laquer thinner and scuffed lightly with scotchbrite pads. When dry, then primed all HS ribs and spars with NAPA 7220 self etching primer. On the HS610 and 614, which are steel rather than aluminum, I added a topcoat of NAPA 606 enamel over the primer.
