Brief Description: Confirmed Elevator and Rudder Travel
After the rudder and elevator were mounted I confirmed their travel against the required specs from Van's. The elevator is measured with a digital level and my elevator has a 27.1 degree up travel and 23.9 degrees of down travel. both are right in the middle of the allowed range.
The rudder was measured against a template I made of cardboard. The accepted range is 30-35 degrees and my rudder is again right in the middle of the range.
