After the elevator was mounted I routed the wiring for the electric trim tab from the rear fuselage through the elevator and into the trim motor. I had pre-wired the trim motor and fitted the unit into the elevator earlier and it was easy to install. I attached the wire connectors and used heat shrink over these.
