Brief Description: Attached Strobe Light to Lower Rudder
I worked on attaching the strobe light to the lower rudder fairing. I drilled the tip to fit the light, and drilled for the attach screws. I then epoxied nuts into the fiberglass tip. Putting a screw into the fiberglass didn't sound like a good idea, and there isn't enough space for a nutplate of a loose nut, so this seemed the best option.
After drying and a little sanding the light is installed and fits nicely.
