I had previously did a rough trim of the fairing and had drilled the screw holes and installed nutplates in the fuselage, VS and HS. I tested the fit and there are a few areas with gaps between the fairing and the skin. I also did some more trimming and also used a heat gun to try and get a tighter fit, but I will have to make some modifications to the fiberglass.
