I sanded the gear fairings after the application of Smooth Prime and discovered a couple low areas that required filling. I applied some epoxy fill to these areas and set aside to dry.
The spinner, empenage fairing and gear leg fairings looked good so I primed those.
I also began attaching the wing tips. I started on the left wing and connected the electrical wires to the position and strobe lights, and the marker beacon antenna in the left tip.
