Brief Description: Wheel Pants and Tire Inflation Access
Many RV builders drill an access hole in the wheel pants to check tire inflation without having to remove the wheel pants. I drilled 3/4" holes in the outer sides of each wheel pant so that it will align with the valve stem. I got plated discs that will cover this hole. I also bought a valve cap removal tool and a combination air pressure guage and inflation tool. these items will make it much easier to check and adjust tire inflation.
I spent some more time sanding the gear fairings then brushed Smooth Prime on all surfaces to fill pin holes.
