Brief Description: Gear leg fairings and wheel pants
With the intersection fairings epoxied to the wheel pants I began sanding and fitting the halves together. This is a very slow and repetitive process. I have to install the wheel pants, check the fit and sand or file to get it right. Then I mark any areas that need filler and apply at the end of the day so it can dry overnight.
