Brief Description: Lower gear leg intersection fairing
When I was happy with the shape of the intersection fairings, I drilled for clecos, then epoxied them in place. I also feathered the edge with an epoxy and flox mix and set aside to dry.
I also removed the moisture absorbing plugs from the engine and heated the selica crystals to remove all moisture. When dry I replaced the plugs.
