I finished sanding and shaping the lower rudder tip that I had modified last week. When I first installed the lower tip there was a minor interference with the VS attachment nuts, so I trimmed the forward edge of the lower rudder tip and added some glass. The fit is now good and I inserted the wiring for the tail light and strobe, made the connections and used heat shrink to secure the connectors. Some plastic ties neatened up the wiring bundle then I screwed the tip onto the vertical stabilizer.
