Bobs RV7 Site
RV-7
Wing Tips - Marker Antenna
I epoxied the Marker Beacon Antenna inside the bottom of the left wing tip. I also fitted the aluminum insert to the aft edge of each wingtip, drilled, then riveted in place.
RV-7 Home
2286
Administrative
Baffeling
Cowling
238
140
Empennage / Elevator
Empennage / HS
Empennage / Rudder
Empennage / VS
241
Instrument panel
163
Landing gear & brake
Systems
Upholstery
183
